Devoredude's avatar
Devoredude
Shower Cover - Double ?
Another new class A owner question. 07 Terra LX 31M. Noticed in the shower the skylite looked cracked or broken. Got up on roof and it is almost gone. THere is a second skylight inside and the primary outside. Never seen anything like this? If it rains into the space between, the water goes where, between the roof and ceiling? Yikes! So, another fix. Not sure how to post an image, but tried.
Anyone clue me in on this Engineering double bubble shower skylight cover marvel? Thank You.
  • Our's is the same double layer.
    Probably for insulation....don't know for sure though.
  • sowego wrote:
    Yes they are all, at least the ones we've seen,two layers. It is good you had the inner if the outer is gone however, water was still able to enter the ceiling of your rig. You'll need to remove the inner, check for moisture and let it air dry before replacing both. If this rig is new to you...someone sold it to you that way?
    I bought it as is, but it didn't come like the pic shown, there was just a small crack and small quarter size hole on the side of it, I pushed on it and it crumbled like a potato chip. The inner cover is clean, pliable, and there is no indication of water every being in between these two covers. The outer cover is approx. 26x18
    and it look like I can get a decent one here
    http://www.pplmotorhomes.com/parts/rv-vents/31-3154pp.htm
    Or I may just order one from Fleetwood if need be.
  • Yes they are all, at least the ones we've seen,two layers. It is good you had the inner if the outer is gone however, water was still able to enter the ceiling of your rig. You'll need to remove the inner, check for moisture and let it air dry before replacing both. If this rig is new to you...someone sold it to you that way?
  • rhochnadel wrote:
    You need a new outer cover pronto, they are not hard to replace.
    No reason to mess with the inner cover I assume, where the heck would the water go between if it rained with this like it is, flood the inner roof? That is pretty scary.
