ggoguen's avatar
ggoguen
Shower door adjustment
I have a 2013 Thor Daybreak 32HD, the shower door is hitting on the bottom outer edge, not the hinge side, it looks square except for the bottom. I don't see any way to adjust the door. I have replace the lower seal, and it is torn up again. You have to pull up on the door to open it. Any Ideas?
  • I've got the same problem on mine, I shimmed up the hinge, it was fine for 10 minutes and then it did it again.
    What I noticed was the upper bracket flexed allowing the door to droop. If I push in on the upper frame, opposite side from the hinge, the bottom of the door lifts and it opens and closes smoothly.
    I'm trying to decide how to stiffen up the upper frame to solve the problem.
  • Worn out hinges or door frame out of square. Push up on outer bottom. My wife tends to push down on the top of the door, Ill bet someone in your household does the same thing.
    Remember, these frames are only held together by one screw at each corner, so they move very easily.
