i have a 2012 coachman freelander that leaks water .any thoughts on fixing would be help full. i found the fitting on back of valve to be not tight from factory . caulked around valves where leaking ....
should be a gasket under the shower valves, if not there's your problem, or if it wasn't winterized it prob has a hairline crack in the assembly. replace it, it's easy
