i have a 2012 coachman freelander that leaks water .any thoughts on fixing would be help full. i found the fitting on back of valve to be not tight from factory . caulked around valves where leaking ....
i pressure tested valves after finding loose connection from factory and sealed all this almost stopped the leak . should there be a strip of sealer under the frame of shower like the gray stuf u see on older campers ?
