i have a 2012 coachman freelander that leaks water .any thoughts on fixing would be help full. i found the fitting on back of valve to be not tight from factory . caulked around valves where leaking ....
I caulked (with clear stuff) all around the frame of the shower, and both sides of the sliding door track, in BF's trailer. There was initially a problem with water running out under the sliding door track.
