bhivetravels
Apr 26, 2014Explorer
bcbounders wrote:
Hi Jim & Monica,
Sorry to hear that the Scrubbing Bubbles caused streaks like that! It's certainly possible that it has "etched" itself into the surface of your shower walls... which would be a real bummer.
I've found that baking soda is another great helper in the shower... since it makes the water so soft, it really helps to dissolve soap scum, etc. And you can leave it a little "thicker" so that it has some slight scrubbing action. You just don't want it TOO scrubby so that it doesn't scratch.
Another helpful tip I picked up from the guys at HowToRVgeeks.com was to use car wax on the shower walls & glass. Sounds like a weird solution, but in conjunction with squeegeeing the water off after showering, it really makes it much easier to keep the shower clean... no spots and less soap scum! You have to really clean the shower first before applying the wax... but if after doing that you use a cleaner/wax, it may help remove the streaks left by the Scrubbing Bubbles.
Here's the video from HowToRVgeeks (the part about waxing comes up around the 2 minute mark):
http://howtorvgeeks.com/quick-tips/get-your-rv-shower-ready-to-roll/
Best of luck!
Ok my weekend job is set as I wax my shower! Thanks to all the helpful suggestions we are trying them all!
Jim and Monica
38,768 PostsLatest Activity: Nov 21, 2015
