Vic65's avatar
Vic65
Shower wall enclosure
Hello I noticed the other day that my shower wall enclosure is starting to pull away from the wall. There is water damage to the wall. The glue is only pulling away in some areas. How do go about glueing the show wall back.
  • I believe the shower walls in most rigs are glued in areas, not across the entire panel. So as the house twists with the road and such, you will notice it more or less pending the last twist of the house. I should also mention that driving up on blocks or jacking of the frame for leveling will cause the same twisting.
    The bottom line is: It's okay, it's normal, yes it's strange but don't worry.
  • DrewE's avatar
    DrewE
    Explorer III
    Is this a one-piece plastic shower stall unit? If so, they frequently are designed to only be attached in a few points to the wall so as to permit things to flex. I would try to verify the source of the water damage; if you have a vent or a skylight over the shower, check that it's sealed properly to the roof and pull the interior trim if possible to check for signs of water intrusion there.
    To glue things in place, if that's how they were originally mounted, I'd look for a construction adhesive that's compatible with the shower stall material. PL Premium is one that I've used with good results for various tasks (though not specifically for shower installation).
    Some pictures of what you're up against may help get more specifically useful responses.
