CREATO
Feb 08, 2014Explorer
JimMartin wrote:
If the pump is bad, What the best replacement pump for my RV?
This one is a 2.8 GPM pump. Can I buy a higher volume pump ( maybe a 3.5 GPM pump) and replace this one without having to change anything else out?
Yes you can put a higher g.p.m pump in it but I think you have a air leak and a new pump won't solve that. Also there is a pressure valve screw on that pump but I can't remember if you turn it clockwise or counter it could be stuck. I would play with that a bit it helps if you have some one to turn faucet on and off while doing it if in a hard to reach place. Another thing you can slip a hose on the suction side and fill a 5 gallon pail see what happens. Had a friend that had a bad cracked pickup tube in the fresh water tank done the same thing.
38,769 PostsLatest Activity: Apr 24, 2002
