MrWizard
Apr 24, 2016Moderator
is it pumping water ?
it will run backwards if the wires are reverse and will not build pressure and shut off
if its pumping water, start at the pump head and remove the wires plugged into the pressure switch, switch is defective or wired wrong, or adjusted wrong
38,782 PostsLatest Activity: Sep 10, 2026
