dougrainer
Jul 21, 2016Nomad
Shurflo Pumps have a Thermal Overload built in system. IF the motor runs too long with no load, the motor heats up and the Thermal switch stops the motor. When the Pump cools down, it functions again. From the Shurflo owners manual. Doug
Is the motor hot? Thermal breaker
may have triggered; it will reset
when cool.
4 Gallons per Minute55 PSI, 10 Amps Max, High PerformanceReduced Cycling with Flow Reaction Technologymooth, High Powered FlowRuns Dry Thermally ProtectedSelf Priming to 6 Vertical FeetInternal Bypass-Low CyclingBuilt In Check Valve Prevents Back Flow
when cool.
38,777 PostsLatest Activity: May 24, 2026
