1. Did you replace the filter with the exact replacement?
2. Did you turn off a valve to replace the filter?
3. Can you hear the pump operating?
Start with the easy stuff. Remove the filter and turn on the pump. Do you have sufficient pressure TO the filter assembly? Reinstall the filter and operate the pump again. Do you have sufficient pressure PAST the filter? Obviously your issue is located around the filter. Check also though, the filter AT the water pump. Sometimes debris gets loosened when you're messing with the water lines. My best practice is to remove all filters at the same time including the wire screens in the faucets and the wire screen in the valve where the water hose attaches. Everything gets cleaned together and you're good for another 6 months or so... Let us know how you make out....Dennis
