Fifty4F100's avatar
Fifty4F100
Shurflow pump won't work
OK I finally found my water pump. It was hidden in plain sight. To help my lowered ego, it was directly behind my main drain line (read: 3 1/2" pump behind a 4" pipe).
Now for my real problem. The pump worked great until we used it the 1st time this spring which leads me to think that it froze and was damaged over the winter. I did use the compressed air method for ridding the lines of water. We last used the MH for a late October vacation. There are are no other freeze problems with the rig. I don't know (other than using the alternative 10 gallons of RV antifreeze method) what I could have done. It looks like some water could have pooled in the diaphragm area. But I don't know why even freezing would cause the pump not to be at least turning now. It won't budge. I can see the power drop (lights dimming) when the pump is turned on, but nothing happens.
Do I need a new pump?
