dougrainer wrote:
beaubeau wrote:
Thanks for the replies! Very encouraging.
Sorry, bad news if you are replacing the Arm and the mirror head. Tiffin foams in the 4 mount bolt nuts and washers and you will have to chip out that foam to get access in the front inside cap. Also, be VERY careful when chipping out the foam as the Camera and mirror motor wires are encased in that foam. If you can replace just the head and you are careful, you can splice the wires except for the camera wires. Usually, the camera has a quick connect inside the Mirror head. Doug
PS, YES, I have replace dozens of Tiffin mirrors over the years
An added point... When Tiffin installs their mirrors, they hook up the mirror head to the wire harness in the arm, pull the harness tight from under the front cap and THEN FOAM OVER THOSE WIRES AND 4 ARM BOLTS. You'll probably have to at least dig the wires loose from the foam. Tiffin is definitely not overly generous with this part of the wire harness.
