NeverHome2
Sep 03, 2015Explorer
Ours is a rear radiator and I like it. While moving on the highway the big rear area of the coach is a low pressure area due to the large hole the coach makes in the air. This greatly aids the fan in moving heated air thru the CAC and the radiator which greatly increases the efficiency of the system.
I changed the fan belt last December and the hardest part was getting the cold belt past the damper and the motor mount done from underneath. I was able to move the tensioner from inside the coach. It was not hard at all.
