hotjag1's avatar
hotjag1
Explorer II
Apr 19, 2017
Sight glass in coolant tank leaking
Coolant is slowly running out at the base of the sight glass on my overflow tank. I noticed that the sight glass screws into the tank. Making sure it was tight didn't stop the leak.
Has anyone had to replace the sight glass? If so, is there an o-ring used at the base or is it a small gasket? Also, are either one of these available at auto parts stores? Thanks in advance.
  • Does your tank have a standard looking pressure cap? If so it is not just an overflow tank. You cannot buy these at auto parts stores. Contact Tiffin for more info. But you might be able to stop the leak with sealant on the threads.
    Moisheh
