zcatcreative's avatar
zcatcreative
Signal Lights Not Working
I just purchased my first motor home, a 1986 Windjammer with 22,000 on it. Love it. However I can not get the signal lights to workI can not get the signal lights, nor the four way flasher to work.
Tail lights, break lights, backup lights do work.
I found the fuse box, by the drivers left knee, and all fuses look good. I can Find NO WHERE where a flasher might me plugged in. Does anyone know if this vehicle has a flasher, and if so where? Does anyone know if this vehicle has a flasher and if so where?
Other suggestions to get the lights to work?
Help!
  • j-d's avatar
    j-d
    Explorer II
    Pic won't display till you post it to a website.
  • The WD40 worked on the 4 way! Tried it on signal light, so far they have not worked. but I now assume is may be connections somewhere... like the fusebox. My bet is the same flasher activates with both
  • Not sure about a 1986 but later years had all the lights running through the emergency flasher button. If that button sticks it can cause all kinds of weird brake, tail, and signal lighting problems.
  • j-d's avatar
    j-d
    Explorer II
    On the chassis similar to the OP's that we had, there seemed to be separate flashers. Parts lookups indicate that too. We know where the Turn Signal Flasher is, corner of the Fuse Panel. OP can confirm by pulling it out and seeing if the Four-Ways still work. If they still do, then clearly they have their own flasher. Might be possible to listen under the dash and hear it click. The flashers were one of the few things we never tinkered with on that '83 E350. Replaced some lamps, but that was it, the nearly 10 years we owned it.
    In some vehicles, there's a spring clip under the dash that holds the top of the Flasher. In a vehicle that old, I'd expect the Flasher to be out of the Clip, dangling someplace. That makes it quieter since it doesn't have the Dash to reverb on.
    It's time to get busy with one of these:
    Far easier to check automotive circuits than dinking around with a Meter.
  • If both the flasher and directional signals fail then it can't be a switch problem. Check the fuse box. You have standard fuses in your 86 vehicle. Wrap tin foil around the fuse until you get to an auto parts store.
  • Wrap it in Foil" I LOVE IT!!!
    I used to always carry foil but it's been so long I forgot about it. THAT is a BEAUTIFUL response!!! Thanks!. will do
