phays
Jan 13, 2018Explorer
I believe the JR500 version of JIB has a serial connection. There are adapters available to convert the serial connection to USB but one needs to check with Silverleaf for the recommended adapters.
I ran with the serial version and finally upgraded to the USB JIB several years ago. I traded the serial JIB in on the USB JIB but can't remember what I was given for it.
Also, you can patch into the transmission plug wires if you don't have an engine connector handy. Both this coach and my previous coach lacked an engine connector up front and I was forced to patch into the transmission connector. Someplace on the Silverleaf site are directions for using the transmission connector.
