SoCal_Kevin
May 30, 2016Explorer
Sink Leak Fix
I recently noticed a leak from my kitchen sink. It was coming from between the sink and the strainer / drain. As I took it apart to fix it I found the way the strainer / drain was originally installed was with a thin rubber or plastic seal. The seal went the way of the dodo. As you can imagine after all these years, it was dry and brittle and not doing its job. I fixed it with some plumbers putty. Easy.
The reason I am posting is a reminder that if your rig is... shall we say, "mature" then you may want to proactively fix this too. It is a leak waiting to happen...
