Southwind98
May 17, 2013Explorer
I have a 2008 Bounder and when I flipped thru the mode selections the first time as you already stated FM/Am/Aux1/Aux2/Weather/and Sirius would pop up. The activation code would be displayed, which I activated. Odd that it is not cycling thru the selections, even if it not getting signal. Almost like someone deleted it from the selection process, which I doubt could be done. If this helps you at all, my Sirius external box on my RV is located under the dash on the driver side near the brake pedal, with the antenna located up on the roof on the front cap of the RV. Good luck.
Also just a heads up, I installed a twelve disc CD changer up in the cabinet over the driver side. The CD player on the radio will skip if you hit a severe bump.
38,780 PostsLatest Activity: Jul 20, 2026
