Davydd
Oct 02, 2014Explorer
cjscotty wrote:wincrasher65 wrote:
There is plenty of space on the roof. The wiring would be a snap as you could go down the back of the closet cabinet. Problem is you have to drill a hole in the roof of your van.
Right now I've got a portable 120 watt panel that works pretty well.
Considering this van is pointed towards the sports-active types, and not necessarily full-timers or long term campers, solar may be seen as unnecessary. If you are just over-nighting in non-cold weather, the single battery will easily last 24 hours until you start up and drive the van. Also, since it has a generator, you have that charging option too.
Is the 120 able to run your air conditioning? We would probably get the portable then, they look to fold up fairly small. We are not full timers, always out for 2-4 day weekends, day trips and a couple week long, but really would like to have this, as I believe the Travato only has one battery?Also looking to go out now for cross country skiing. We have 2 on our current, and even short timing if the battery dies or we use it up for some reason not going to be too good. We have 2 small dogs also we take everywhere. May open up more options for us also. I know we dry camp in state parks a lot and they have limited generator times, and we have gotten banged on our door by angry campers. :o
A 120 W solar panel is not going to run much of anything. A rule of thumb I've read says, a 100 watt solar panel produces an average of about 6 amps per peak sun hour, or about 30 amp-hours per day. So a 120 watt panel might be good for maybe 36 amp-hours per day. When I quoted that on another board some experienced rooftop solar panel Class B owners suggested the rule of thumb might have been generous. Air conditioners are going to use anywhere from 85 to 125 amps per HOUR of use. An aimed portable solar panel might exceed that rule but still would not be remotely close enough to run an air conditioner. Then a portable solar panel is one more thing you have to carry, pack away and take up valuable space.
