pwrchrd
Feb 03, 2015Explorer
Sketchy issue
Greetings, I purchased a 2006 Winnebago Outlook last May and the Onan generator said it had 118 hrs on it! Ran like a champ! The last 4 months of the year I didn't use the generator and when I tr...
pwrchrd wrote:
Greetings,
The last 4 months of the year I didn't use the generator and when I tried to start it it would simply turn over but not fire. I figured gummed up carb so I took the two wing nuts off the air cleaner housing and the air filter, pulled the filter, squirted gumout and starter spray in and turned it over, still wouldn't start. Took it into the repair shop and they called today to tell me that the choke assembly was "disassembled". Since I know I didn't take it apart, and this was working fine, questions;
1) Can they rattle apart?
2) Could the repair shop have swapped generators on me during another service engagement in the last 4 months? Wondering how one would know since I don't see serial numbers for the generator listed in the original docs I have for the rv. Is there a way to check an internal hours meter against the gauge in the RV?
Note: Generator panel was locked but I would bet those are pretty easy to pop open.
Waiting to hear back if this is a warranty item.
