toedtoes
Jun 07, 2014Explorer III
If you're set up (and/or going to) where you can easily regulate the temperature inside the RV (e.g., hookups, generator), then sleeping bags are easier to manage on the beds. Using a bag liner reduces the need to wash the bags as often.
If you're set up like I am, camping in mostly no-hookup sites and no generator, then a sleeping bag may not be versatile enough. I use sheets, a down-alternative blanket, and a cheap comforter. I push down what I don't need, some nights only using the sheet. I find it much easier for varied temperatures than a sleeping bag, and sticking out your feet is possible. I also have several of those wonderful throws that Costco sells in winter to use if I need even more warmth.
38,782 PostsLatest Activity: Sep 10, 2026
