So I extended my livingroom slide. I was looking out the side mirror and the slide seemed to be coming out as usual. I hear a pop. As it turns out, the front of the slide extended all the way and the ...
Happened to me a few years ago. The mobile tech actually called HWH for help and was able to get my long slide in (opening valves using crank and some man power). I then had to take it to a HWH dealer for repairs to the slide section that had popped all the fasteners along the bottom where the outer wall connects to the bottom. Screwed and glued, then good as new. Never knew what caused the problem, and it has never happened again, go figure!
