I am in need of a sanity check. I have had the front drivers side slide floor replaced. I went to pick up my coch Saturday and found that when closed, the floor stuck up about two and a half inches ...
Did you replace the floor with carpet or hardwood/tile? There should be a flap sticking out the end of the slide on the inside about 6 to 8 inches long that droops down to cover that gap you see. If you replaced with hardwood/tile, then there is no way to cover that gap. can you post a pic of the gap? Doug
