- bobndotExplorer IIILook into finding the location of the slide-out relay or fuse.
Depending how the wires run to your slide, a wire could have been pinched by the slides movement.
Check youtube , there are tons of slideout repair vids. - way2rollTrailblazerDid you mean Freelander? Likely in a bin or under the steps. Do you have your battery disconnect turned on? Have you tried plugging in to shore power?
- opnspacesNavigator IIIOpen the coach door and see if the top of one of the steps is screwed down. The battery might be under there.
