Have a 2007 Damon Daybreak. Living room slide goes out perfect but when coming back in it really does not want too. Super slow!! This slide is a rack and pinon slide. When it closes its flush and seal...
Keep the coach plugged in or run the engine so that the batteries are above the 12.x volts that you would see with them resting. With the batteries at the 13+ voltage, the slide motor will run better. With no help on the charging side, your batteries will sag below 12 volts when the slide motor runs
