Gdlow's avatar
Gdlow
Slide issue on 2005 dolphin
Just happened to notice a 3 or 4 inch wide strip the length of the slide depth and running in the direction of the slide moving in or out. Any thoughts on cause and or fix, would be appreciated.
  • There is a mechanical disconnect underneath that allows you to manually retract the slide. Sometimes this gets disengaged and the slide will wander out a few inches.
  • Executive wrote:
    Slide needs adjustment. You'll have to find where the slide mechanism bolts and adjust as necessary. Otherwise, have a mobile mech come and make the adjustment for you. Some are easier than others. If it appears to be above your pay grade, let the professionals handle it. Cheaper for them to fix it than it will be to fix what you broke. :)...Dennis
    It is well above my pay grade...had new slide motor put in about 4 years ago! But just now noticed the issue.. thanks
  • Slide needs adjustment. You'll have to find where the slide mechanism bolts and adjust as necessary. Otherwise, have a mobile mech come and make the adjustment for you. Some are easier than others. If it appears to be above your pay grade, let the professionals handle it. Cheaper for them to fix it than it will be to fix what you broke. :)...Dennis
