zach477 wrote:
dougrainer wrote:
You are looking at the problem wrong. IF the Lock interface system does NOT tell the slide system if the locks are in the correct position, the slide system will not function. So, you need to verify which of the links we have sent you is your slide lock system and find the problem. MOST time on an HWH slide lock system, it is the Magnetic switch (there are 2/front and rear) that is not sending the correct signal to the HWH control box. Doug
It's this one.
Link
Where do I look for the magnetic switches?
I have never worked on this hybrid system. Only the combo HWH slide room and slide locks. THAT HWH system the magnetic switches are located under the Heavy slide tubes by the lower slide room wipe seal. Doug
