fairway2002 wrote:
I had this problem on my last rv. When the pump would bring slide in the locks will close and lock. My vale would leak a little past valve. Causing slide to come off the slide closed switch. Locks would not work with the slide home switch open. I was able to keep hitting extend switch until the locks retraced a little. Then close slide and pump would run an hit home switch. Or keep hitting extend until locks oped all the way
This might be tricky then. On my rear slide, all of the slide assembly (rails, motor, etc) are under the bed and difficult to access. Especially with the slide retracted.
Zach
