pwrchrd's avatar
pwrchrd
Slide motor making clicking sound
Greetings,
I have a 2006 Winnebago Outlook that the slide motor failed and was replaced under an extended warranty I bought. The service place I took it to said the motor and actuator arm had to be replaced together ($2500!) and the warranty company authorized the replacement. When I got it back they showed me the slide working, and it made a ticking noise during out and in. Worked fine, but just had a noise where it didn't use to have a noise prior to completely failing. Their technician told me that after I actuate it a few times worm drive should lubricate itself and the noise should go away. After 10 recycles, the noise is the same. I took it back in and they said that it appears to be working properly but the motor has a wobble to it.
Should the slide motor wobble like the video link shows?
Slide Motor video
