MrWizard wrote:
Additional info: So today, Oct 11th, got ready to head on out and slides wouldn't work. Kinda expected that so set up an electric space heater with fan on a step stool around a foot from the hydraulic slide assembly. I'd been waiting since 9ish and tested several times just trying to pull in the slides before I went with the heater. Only ran it around 5 minutes and the slides started working. Air temp was 44F. Ok, after a night of 20F, close enough to the temp that previously made it work so could be a coincidence.
this seems a generalization
exactly what did you warm up
the pump
hydraulic cylinders/rams
hydraulic gearing/drivers
solenoids
I have a 750 watt room size electric heater with fan. I took it outside, and set it on a small single step stool on the ground aimed at the hydraulic assembly from about 12" away. So yeah, I warmed up all those items you listed that also are on the hydraulic manifold (see picture I posted earlier).
Like I mentioned though, the heater wasn't running very long and the slides started to work again. That may have been a coincidence. I might have the opportunity to test that again tomorrow as I'm set to leave here (Winnemucca) before 11 am and it's suppose to get down to 16F tonight.
