captmike's avatar
captmike
slide out ?
Just bought a 2000 Kountry Star 1st time we put slide out and got ready to bring it in, when we mash button it tells us to unlock locks, then tries to go out and cuts off. Will not try to bring in. It has center motor (single motor). So I have power to motor and switch, best I can read that means board it good, just will not bring in, what's next?
Thanks for the help
I am newbie
  • dougrainer wrote:
    crasster wrote:
    This may help as well.
    https://www.youtube.com/watch?v=3aCEYtHPMIM
    That is a lock arm system developed in the past 5 years. 2000 Newmar has a MANUAL Lock system. Not even in the same ballpark. Doug
    Doh! Yep, missed the year totally. Saw Kountry Star - the coach I'm saving for. :)
  • Thanks for the help, if all else fails have wife read owners manual. Work find if you know how.
  • Not the same brand as yours, but my lock is electric and a rocker switch next to the activation switch to run the slide-out in and out. If you have an owner manual, look and see if there's a schematic that shows the wiring for the slide-out. That may help.
  • 1. The Lock/Unlock voice will activate in both extend and retract modes
    2. Are you plugged into Shore Power? If not, turn on the genset to get the Power Converter to help power the system.
    3. On Newmar, when a motor stalls, the BEST way to test for either a Bad Motor or the Control is to disconnect the 2 wires to the motor at the motor and attempt to retract with a good 12 volt battery source direct to the 2 motor wires. IF the room retracts, then the odds are the Control is bad. If it does NOT, then the motor is bad. IF the motor is bad, the only way to retract a Newmar slide is to loosen BOTH "Trans-Torque" Bushing nuts at least 4 turns. That releases the motor from the driveshaft and then you can use a pipe wrench to manually turn the driveshaft to retract the room. When I state 4 turns that is because when you attempt to release those nuts they will break loose about 3/4 turn and some think that releases them. It does not. You then break it loose a 2nd time and turn at least 3 more turns.
    4. I assume you have the Level floor slide out. That points to a bad motor as the short 8 inch slide UP the ramp is what causes a bad motor to stall. You could also have 3 or 4 people on the outside PUSHING the room in while attempting to retract instead of releasing the Trans Torque nuts. With that extra help you may get the room up the ramp and once on the level floor the motor may continue to bring it in. If you can do this and it works, then replace the motor.
    5. Also, look at the Motor and Transmission case. See if you see any green oil on the case or dripping off the case. If so, then you have to replace the motor. Newmar sells the complete motor/trans as a unit. Doug
  • You should have a tool to unlock the slide locks on each side of the slide outs. You should be able to see the front slide lock behind the drivers seat. It will be an articulated bar that when push up is in the lock position and when pulled down will unlock and be in a slight "V" shape. As the slide comes in the "V" will become more pronounced.
    Thanks for the help
    I am newbie
