Pass42's avatar
Pass42
Slide Out Awning Replacement Fabric
Has anyone ordered from Tough Top Awnings??? Good quality?? Any issues??
  • We did ours last year with fabric from Tough Tops. Came quickly, very heavy good quality fabric. Install is a 2 person job for sure, DW fed fabric in, keeping it aligned and level while I stood on the slide and pulled.
    Tips: I went to Home Depot and bought a strap wrench, made unrolling the awning roller tension very easy.
    Be very careful where you spray whatever you use to lube the fabric/grooves. I got silicon on the fabric where I was trying to grip it and it made it very hard to pull.
    Also don't use a highly tempered pin to hold the roller, The tension snapped a small drift punch while a good old common nail held perfectly.
