ElCaminoManT's avatar
ElCaminoManT
Slide out corner trim?
So these trim pieces on the corners of the slides of our new-to-us motorhome are pretty sad...
As you can see, a couple need to be replaced but I'm having quite a time finding these things. There is a company making them out of aluminum that i found...but at $160 a piece? x8? Um....seriously?? Anyone know of any other sources online for these or are they a thing of the past and I need to look into a different design?
I'm guessing this would be my next option?
Thanks!! :h
  • thank you for the replies and links, much appreciated! and yes, i plan to paint them before installing so they won't turn yellow in 2 months! :)
  • They are called KITES by some OEM's. They are usually WHITE and turn that yellow from UV age. Jayco and Tiffin sell them. Doug
  • I ordered replacements thru my local RV service center from the coach manufacture then painted them before glueing in place. Raw plastic will yellow with time. Only replace the bottom edge pieces that were cracked and painted the top corners that were in good condition but yellowed. I'm guess but is the coach a Hurricane?
  • You might try here: http://www.factoryrvsurplus.com
