dougrainer
Jun 30, 2013Nomad
Most older Tiffins the drivers side slide is motorized. There is a BRAKE lever on the end of the slide motor and if NOT engaged, the slide will extend a few inches. Check the motor and if you see the brake tab it will state which way to engage. IF you have the HWH slide, then one of the 2 solenoids is leaking internally. Doug
