Bedroom Slide out won't stay in, in rest area outside of Des Monies. Headed to Indiana how to keep it in and if we open it at night will it stop at end so we can just push it back in. Thank You
Look under the slide and see if there is a "brake lever" at one end or the other of the slide mechanism under the floor when extended. Sounds like the brake has somehow released itself. I had this happen one time with a Fleetwood class A, so it can happen, All I had to do was push the lever back to the brake on position and it stopped the slide from moving on its own.
