Bedroom Slide out won't stay in, in rest area outside of Des Monies. Headed to Indiana how to keep it in and if we open it at night will it stop at end so we can just push it back in. Thank You
Some slides use a worm gear to run them in and out. Underneath, on the motors, there is a small lever that engages the gears or disengages the gears so that they can be extended by hand. Perhaps on your coach, the lever has moved and it is allowing the gears to be free and the slide move out. Be sure to check both motors if your slide is that type.
