tropical36
Oct 29, 2014Explorer II
2 Retired wrote:
We are dealing with an ongoing problem with our slide on our 2006 32' Georgie Boy Pursuit. The RV has been in the shop 5 times in the past 5 months. The slide out will either not open or not close. At times the motor is running on the slide but not engaging. The shop has replaced the "PIN" three times and then used a bolt in its place. They say they open and close the slide numerous times with no problem, but it does not function properly when we try in our driveway. This last time it went out without a problem but will not retract. We have always used the Big Foot leveling system prior to sliding out to be sure the rig is level. The owner of the RV repair shop told us that may be part of the problem, that doing that prior to sliding out may cause something to "bind" and break the pin. Anyone had this problem or know if he's just blowing smoke at us? He has "guaranteed" the issue will be resolved and, of course, will do it for no charge. I'm very skeptical but DH is willing to give him one more shot.
It actually sheared a bolt, as well as some good twisted type pins? Sounds like maybe the sliders that meet the floor are worn, making for a lot of frictions and requiring more torque than normal, assuming that it's not being obstructed in some other way. Waxing the floor when the slide is out usually helps, but is seldom the complete answer for a problem such as this.
We've never sheared a pin, as yet and it seems like it would take a lot of torque to do so. Then again, I think that our control board has a current limiting device built in, even though it might be set pretty high.
38,780 PostsLatest Activity: Mar 30, 2014
