- bobndotExplorer IIIyes, I agree, a very poor design.
After 11 rv's I'm a little tired of getting burned.
That's why I always advise people to strike up conversations with the guys that repair them before they buy. Doing that has saved me from buying certain rvs. But I guess a lot of people are gamblers and let the dice roll .
If you had known that about the slide removal to access the motor, would you have still bought it , knowing that they use 12v cheap motors in these things ? Nothing is quality in rv's, you have to limit your down time and lack of use. - bukhrnNomadmy 29' Forester needed the drive gear replace on one of the slides, i took it to repair shop, the entire slide has to be removed to replace it. Pretty P-ss Poor design. :E
- bobndotExplorer IIIWell Anthony its been 24 hrs. Do you still need help ?
- klutchdustExplorer IIWhy and how was the slide motor failure diagnosed. Slide motors often shut off on internal protectors due to the slides being
gummed up. The slide will go out a foot then stop, out a foot then stop. Cleaning the slides then adding silicone ,not grease, oil,wd or anything that will collect dirt,
has remedied my bedroom slide many a time. Also, if you are looking at the slide from inside the coach, seal all entry points for plumbing, electrical etc.
I camp in the desert, dusty ,dusty, dusty. The fine silt was getting into my coach and sticking and gumming up my slides. Once I sealed those entry points my issues have lessened dramatically. - wanderingaimlesExplorerWith no information as to type of RV, type of slide, age of unit nobody can help.
Start by listing year, make model and if possible a picture showing the type of slide your dealing with.
Also you may get help on YouTube
Heres what I got from a simple search.
Remove slide motor
