My friend has a 2008 Damon MH with 2 slide outs.when parking at a campsite the motor must be shut off before the slide outs will extend.After they are extended the motor will start and the MH can be d...
My foretravel would not go into gear if the slide was out. It would run but not go into gear. Also the slide would not deploy unless the park brake was on. There was an override switch in the HWH box that let the coach go in gear if need be.
