tropical36 wrote:
cobra350 wrote:
First time this has ever happened to me. I started the motorhome to move it today. It has been sitting about a month. The living room slide started going out all by itself. I ran back to the controls and the in button was lit up but it was going out. I could not stop it. It went all the way out and stopped. After that it worked fine. It has been plugged in the whole time. Any ideas? 08 Winnebago Journey 37H
I'm guessing and just in case you might have a POWERGEAR unit in the basement compartment. Check for a lever (maybe enclosed in rubber) on the back of the motor that may or may not be spring loaded. This is the manual electric brake release and if fixed, it could've been moved to the unlock position, inadvertently.
If unlocked all the room will do is push out about 2 or 3 inches. It will NOT fully extend if the brake lock is OFF. Doug
