dougrainer
Feb 27, 2014Nomad
The only way to change the rollers is to extend about 1/2 way or more and then push the inside top to lift the floor area up. You then wedge wood shims to keep the room tilted back and then replace the rollers. The rollers have a spring load axle pin that you push in to remove and install. Doug
