Ivylog
Jul 12, 2015Explorer III
Is it the end near the driver's seat or the other probably next to the refer? Most Monaco driver side LR slides are powered by two hydraulic cylinders inside a 2x4" rectangular tube at the bottom that supports the weight of the slide. With it out as far as it will go I would look at the end of this tube to see if the bolts are tight and that the slide has not gotten out of adjustment there on the one that stops. Are there skid marks on the bottom of the slide on that end indicating that end is lower than it should be.
It bothers me that it went from good to bad in one stop. Did something fall down and get behind the slide on the inside... easy to see behind the drive's seat, almost impossible on the other end. Have you tried helping/pushing on the bad end?
Good Luck.
Good Luck.
