I have a 36' gas class a. My living room slide is 12'. I was wondering how much weight can I reasonably store in the compartments under the slide without affecting the operation of the slide?
There are lots of factors to consider. I installed some pullout trays in a vehicle. In the fine print of the weight rating it stated the rating was cut in half if the trays were installed in a vehicle. In an RV the slide would depend if the slide was in or out and parked or traveling. Just be sure you are not fully loaded when you drive with the slide out.;)
