omaziar's avatar
omaziar
slide out
2005 Fleetwood jamboree 31w anyone know where the manual retract is for the slide thought I should find out before I have to know in a hurry. Looked around can't find it myself.
  • Mine had a tin cover over mine was looking at it on right side and was close to outside shell. But on mine you can see the rack. If can't fid it call the company I did this and found what I needed to know.
  • OK so I look all under and around the gears and the rack don't see the motor do I need to start taking off covers? Thanks for the response
  • Look under slide by motor you will see a lever when you flip it you disgage gear box then a few of your buddy should be able to push it in then after you finish push in it, Then return lever so not to come back out while driving. I'm not saying it's easy to push but it can be done.
