bullydogs1
Dec 19, 2014Explorer II
The motor is straining upping the drain/amperage making it blow....check motor to make sure connections tight on it and good ground..that's if you can get to the slide motor...also check any connections from fuse etc...that motor might be on the way out or the slide track needs to be lubed to make the motor strain less on moving it.
1. Check track and lube with proper slide lube.
2. CHeck elec connections that have anything to do with slide.
