dougrainer
Dec 20, 2014Nomad
Install a 25 amp auto reset 12 volt circuit breaker. That way, you do not have to keep replacing the fuse when it blows. Once that is done, you can troubleshoot. Usually, on this type problem on Fleetwoods, the MOTOR is bad. Replace it. It is just plain worn out. There is nothing but the motor from the rear control board that has the fuse. IF the room extends and retracts with no obvious binding, then the motor is bad. Doug
