dougrainer
Dec 25, 2014Nomad
moisheh wrote:
The front slides in those Fleetwoods need to be lubed often. I use Dri Lube. There is also a replacement HD motor for that application.
Moisheh
Do you have the PG part number for that HD motor. The last time I had both Fleetwood and Powergear research the CORRECT motor/trans for a Fleetwood slide(using the PG model on the old motor assbly), they stated they only had the original RPM/Ratio assbly. Doug
