23hotrodr
May 20, 2022Explorer
dougrainer wrote:
http://server51.hwhcorp.com/?page_id=61777
Is this the HWH lock system you have? Doug
Or this one?
http://server51.hwhcorp.com/wp-content/uploads/ml41035.pdf
Or this one?
http://server51.hwhcorp.com/wp-content/uploads/ml39511.pdf
Thank you-- I have the HWH 625 system. I was able to get it unjammed. I also figured out that the 2 micro switches are normally open and the lock must be in the fully un-locked position for the system to move the slide room.
Do you know if I remove the 8 screws going upward around the perimeter of the mechanism into the ceiling of the slide room, it then can be completely removed without doing anything on the outside? It seems very stuck and I did not want to really try and pry it off without knowing for sure. I thought that if I could remove it, I might be able to lube something other than just the drive screw that becomes exposed when moving it to the locked position. Thanks again-- Mick
