winkyb
Jul 04, 2014Explorer
Clay L wrote:
According to Winnebago those are not the seals but are squeegees/wipers to remove water and debris when the slide is brought in. They say it doesn't matter how they are deployed when the slide is out.
The actual seals are the bulb seals that are compressed when the slide is in or out.
That may be but I think what was happening with mine that water was getting under the first seal and running down the track on each side of the slide and would get the carpet wet in a hard rain. The track to me did not go down past where it could not get to the carpet if not parked leaning a little toward the slid out side. Fixing it so that seal would come out and also glued a guard that went below the floor solved the problem.
38,777 PostsLatest Activity: May 20, 2026
